guyworthy
Mar 19, 2013Aspirant
HELP post power failure
After a power failure, the checking file system stopped at 2%. I did not notice this for a day or so. The power button would do nothing. RAIDRAR shows the unit as blue and I cant get to setup. I...
Mar 19, 2013Guru - Experienced User
All this stuff creates some risk to your data. Have you submitted a support request at support.netgear.com?
You could do a couple more things on your own, but the safest answer at this point is probably to wait for support.
