DPH1968
Dec 30, 2020Aspirant
help R102
been using the NAS for monhs no problem, then had a power cut and it went to s##t....can do anything with it.....tried resetting the OS boot but nothing, tried accessing the drive via the admin page,...
rn_enthusiast
Dec 30, 2020Virtuoso
Hi DPH1968
Have you tried to install RAIDar, to see what it reports of status?
Link here: https://kb.netgear.com/20684/ReadyNAS-Downloads
Scroll down to the RAIDar section and install "RAIDar 6.5 for Windows". Afterwards, open RAIDar and check what it say about the NAS.
That is a good place to start.
Cheers
- DPH1968Dec 30, 2020Aspirant
ive installed the software and the status is showing as TFTP_REQ
- rn_enthusiastDec 30, 2020Virtuoso
Yes, this can happen sometimes. Usually a problem with the filesystem on the internal flash (the OS), a failing internal flash (which would mean bad chassis) or corrupt files on the internal flash. You can do a USB recovery to re-install the content of the Flash.
https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-systemWorth a go
- Jul 02, 2017Retired_Member
