DPH1968
Dec 30, 2020Aspirant
help R102
been using the NAS for monhs no problem, then had a power cut and it went to s##t....can do anything with it.....tried resetting the OS boot but nothing, tried accessing the drive via the admin page,...
DPH1968
ive installed the software and the status is showing as TFTP_REQ
rn_enthusiast
Dec 30, 2020Virtuoso
Yes, this can happen sometimes. Usually a problem with the filesystem on the internal flash (the OS), a failing internal flash (which would mean bad chassis) or corrupt files on the internal flash. You can do a USB recovery to re-install the content of the Flash.
https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
Worth a go
- Jul 02, 2017Anonymous
