Redwards92
May 08, 2013Aspirant
HELP! Readynas won't boot.
Hi, last night my brother came into my room to find something and removed the power cable to my ReadyNas. Upon discovering this, I have found it will no longer boot up what-so-ever. Help? Sorr...
mdgm-ntgr
May 08, 2013NETGEAR Employee Retired
Can you confirm that this is a Duo v2 after reading this?: How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
When you press the power button does anything happen?
Do you have the power timer set?
What version of RAIDiator were you running?
