Furax427
Feb 10, 2021Follower
HELP RNDP400U
Help Please! I need the ROOt_ssh or Enable SSH files for my RNDP400U I dont know if it's X86, Arm or sparc . I try all this files : -EnableRooSSH_1.0..bin -ToggleSSH _1.0-x86.bin -Enable-Remote_A...
Feb 10, 2021Guru - Experienced User
Your NAS is x86. The add-on you need is EnableRootSSH.
A direct download link is https://www.downloads.netgear.com/files/ReadyNAS/ADDON/4.2(X86)/EnableRootSSH_1.0-x86.bin
Sandshark
Feb 11, 2021Sensei
But if you can't get to the web admin page, you can't apply it. Are you trying to address it in the form https://NAS_name_or_IP/admin? If you don't use https, it will default to the share page instead of going to admin. Also what browser are you using? It's going to report a security issue due to the self-signed certificate the NAS uses, and you have to use a browser that lets you override that.
SSH is not normally used for NAS admin. There are some things that can only be accomplished through the GUI.
