Crash_HI
Sep 13, 2024Guide
Help with email alerts - Error Code 5008010000
Hi, I have an RN626X and am unable to send email alerts. My firmware is 6.10.10. I am aware that some email systems that require Oath2 authentication cannot be used easily, but I have not been a...
- Sep 19, 2024
I could not figure out how the extraneous entries got into my email alert list or what was causing the send errors, but I was able to get things working by:
1. Removing all Alert Contacts
2. Clicking the Clear button for the Alert configuration (this is probably what flushed the zombie addresses)
3. Re-entering all e-mail fields
4. Setting up an App Password for Yahoo, and using that password in the password field here.
Now the email sends, and I get a clear exit code in the log.
Cheers
Crash_HI
Sep 13, 2024Guide
I was able to get it working after removing some of the contacts from the contact list.
There was an entry for each of these:
Alert
MYACTUALSERVERNAME
I don't know how if these are automatically added when setting up the NAS or if these are left over from a previous firmware version, as I cannot re-add them now.
I wonder if those were important or if anyone has any insight.
Thanks
Alert
MYACTUALSERVERNAME
Thanks
saudade
Sep 14, 2024Apprentice
I have 3 "alert" contact spaces on my Duo. I don't recall any of them being populated. I only use one with my yahoo address.
You can't add them back as they are not valid email addresses.
So did any of them make it to your Yahoo account?
- StephenBSep 14, 2024Guru - Experienced User
Again, they are supposed to be the email addresses you want the alerts sent to. So if they are not valid emails addresses, you should delete them and not try to add them back.
In my case, the yahoo email address and my gmail address are listed, and my gmail does receive the alerts.
