Leothlon
Nov 08, 2015Aspirant
Help with file premissions
Hi. I am looking for a way to set file permission so that any user can create files and folders but can only edit and delete their own files.. Example: User A create file 1. User A has full perm...
BrianL2
Nov 09, 2015NETGEAR Employee Retired
Hi Leothlon,
With the given scenario that you posted, example #1 is more likely to happen but not example #2. Also, confirm the model of the ReadyNAS unit that are you using.
Kind regards,
BrianL
NETGEAR Community Team
