Leothlon
Nov 08, 2015Aspirant
Help with file premissions
Hi. I am looking for a way to set file permission so that any user can create files and folders but can only edit and delete their own files.. Example: User A create file 1. User A has full perm...
Leothlon
Nov 09, 2015Aspirant
Hi.
I have the readynas 104.
Ok is it then possible to delete folders but not files?
So user A create empty folder 1,
User B can delete the folder.
User A create file inside folder 1.
User B can no longer delete folder 1?
Or something along those lines...
- BrianL2Nov 09, 2015NETGEAR Employee Retired
Hi Leothlon,
I thought this was the scenario based on your first post.
Example:
User A has full permissions on file 1.
user B can read file 1 but not delete or edit.If a user has read-write access to a folder or share, he/she will also have delete privileges. Just let me know if you have other questions.
Kind regards,
BrianL
NETGEAR Community Team
