Cardz
Dec 13, 2012Follower
Help with network browsing
Hey all I am after some help with browsing my NAS (Duo V2 5.3.7) via my windows 7 PC. Before when I was on 5.3.5 I could see my Nas fine under my network and I was able to browse and add/remove/rena...
Dec 13, 2012Guru - Experienced User
CIFS is also known as SMB. It is built into all windows systems. If you can map NAS shares to network drives you are already using it.
I don't have a v2, so I can't tell you exactly how to change permissions on the drive. Of course the user name you put into the credentials manager is what determines your permissions on the NAS. One test is to set the username to admin (with the corresponding password) and see if that lets you deal with the file you want to delete/rename.
