ricko1's avatar
ricko1
Help with Services
Hi
I have been struggling for quite a while with my Duo, hope someone can help! The Duo is showing 0 MB (0%) of 0 MB used , but I can see my shares, with quite a lot of data on the disks . when however I check any services , standard file services (CIFS, NFS etc,) they do not remain checked.
Hope this makes sense to someone and there may be some light at the end of the tunnel
Many thanks
Ricko
  • Right - reinstalled OS - can still access shared drives , but cant access frontview - well I can, username & password (netgear1) work - however no graphics, buttons etc, just squares in frontview - tried 3 different browsers without success.........
  • Since OS reinstall did not help and since you have a backup of all of your data, I suggest you to just factory reset your NAS then restore back the data in it.
  • Yip - thought that might be, cheers getting late will try tomorrow
ProSupport for Business
