steveh1955
May 04, 2016Aspirant
How do I delete sickrage links?
Hiya, Love my RN10400 but have a newbe problem! Installed sickrage and love it, only problem is i cannot find any way of deleting the dowload links that are left in the home folder, The only dropd...
- May 05, 2016
Hi StephenB,
Thank you so much the home folder was the problem, once i transefered it all to a different folder, like magic all the option appeared.
thanks once again for your input to a newbee.
Cheers
SteveH
JennC
May 04, 2016NETGEAR Employee Retired
Hello steve1955,
Welcome to the community!
Can you browse the shares using admin account and get to Home folder, I believe you will see a folder for each link or show? Or try getting to the admin page then browse shares then go to Home.
steveh1955
May 05, 2016Aspirant
Hi JennC,
Thank you.
Yes i can get to all folders, and i am accessing by admin account,but the links are not in any of the sub folders they are in the home folder. I can use the links to dowload programs copy the link and see if there are any other versions of it, but when i highlight it the delete option is not there even the X delete icon does not light up and when i right click it all i get is the 3 options download copy version!
Steve.
- Retired_MemberMay 05, 2016
If you're trying to manually delete them from the GUI of the ReadyNAS, do a right click on the file.
Example: https://i.imgur.com/NYcJ58E.png
If you're trying to automatically delete them once the download is complete, you need to look into the option of Sickrage or your torrent app.
- steveh1955May 05, 2016Aspirant
Hi,
Thanks for the reply.
That's the problem though, I right click and the only options i get are as i stated "Download...Copy and Version" I have tried every type of delete options i know but nothing seems to work.
See pic below
Steve.
- StephenBMay 05, 2016Guru - Experienced User
You might be having problems because you put the files in home in the first place. /data/home is a special folder - it is intended to hold user "private" home shares, and not for general use as a share. I don't use sickrage, but I think you should configure a sickrage share that it can use (and stop using home).
Try accessing the NAS from a PC (using file explorer) using NAS admin credentials. That will let you see the home folder, and you might be able to delete the files from there.
