steveh1955
May 04, 2016Aspirant
How do I delete sickrage links?
Hiya, Love my RN10400 but have a newbe problem! Installed sickrage and love it, only problem is i cannot find any way of deleting the dowload links that are left in the home folder, The only dropd...
- May 05, 2016
Hi StephenB,
Thank you so much the home folder was the problem, once i transefered it all to a different folder, like magic all the option appeared.
thanks once again for your input to a newbee.
Cheers
SteveH
May 05, 2016Guru - Experienced User
You might be having problems because you put the files in home in the first place. /data/home is a special folder - it is intended to hold user "private" home shares, and not for general use as a share. I don't use sickrage, but I think you should configure a sickrage share that it can use (and stop using home).
Try accessing the NAS from a PC (using file explorer) using NAS admin credentials. That will let you see the home folder, and you might be able to delete the files from there.
steveh1955
May 05, 2016Aspirant
Hi StephenB,
Cheers
SteveH
