ilikewaffles
Nov 10, 2015Follower
How do I enable the Recycle Bin?
I have a ReadyNAS 102 running firmware 6.4.0. I use it as a central file share/storage for multiple users. I'd like to have a recycle bin, similar to what I'm used to with Windows, so if someone dele...
Nov 10, 2015Guru - Experienced User
There is no network recycle bin in standard OS 6 systems, but it is possible to create on with ssh.
Before you try that though... OS6 snapshots gives you a somewhat similar feature. So you might want to look into that first.
