Squeaky's avatar
Squeaky
How do I fix a capacity problem?
I have a ReadyNAS Duo RND2000 v2 connected to my home network (Windows 7 & 8 PCs). Until recently it looked like this: Slot1 - 1TB Slot2 - 2TB Drives in Redundant X-RAID configuration.   I star...
  • Squeaky's avatar
    Squeaky
    Nov 15, 2015
    Hi StephenB
    Thanks for that link. I checked that the settings were already as specified.  The final step appears to have been a critical one, which was to tick another box under "Shutdown options" - "Check and fix quotas on next boot".  After ticking this and performing a controlled shutdown and restart, I got a message saying that the first stage of volume expansion was underway and that another restart was needed.  Shortly after that I got confirmation "Data volume has been successfully expanded to 1853GB".
    On previous volume expansions I hadn't ticked this box and I hadn't experienced any problems. Perhaps it was the default in earlier firmware revisions - I don't know, but it certainly did the trick this time.
    Many thanks for putting me onto the right track with your advice - it was a whole lot easier (and less scary) than what I was originally proposing to do, and I'm now up and running again. Phew!!
ProSupport for Business
