ScotsDon's avatar
Jun 28, 2022
How do I prevent Alerts being emailed to the Sender (ReadyNAS 104, Firmware 6.10.7)
Following Google's email security change (June 2022), I got an App Password and entered all the details in Settings/Alerts, which works fine, but I now can't stop emails being sent not only to my Ale...
  • Kardano's avatar
    Kardano
    Jul 06, 2022
    There is another solution:
    1. In settings do configuration backup with check: custom - Miscellaneous settings only.
    2. then Download configuration
    3. Zip file you get open in Total Commander
    4. navigate inside zip archive to "etc\frontview\"
    5. Open "Alert.conf"
    6. In Alert.conf file, AFTER mark "!!!" delete sender e-mail, other leave intact
    7. exit and save archive
    8. On setting do Restore of config and use editet zip file
    9. if your edit was ok and file was saved OK (TC worked that good for me) import will sucseed
    10. There is no need for restart, even if NAS say so. You can check Alerts an you will see...
    ..That all is correct and sender e-mail is no longer set as next adress for alert e-mails.
    Easier than downgrade and upgrade FW with all changes...
    Doing it like this from time that error appeared.
