DiBosco
Mar 05, 2013Aspirant
How do I use wakeup on LAN on Duo v2?
Folks, I have a Duo v2. I have it to be on for one hour a day to back up stuff then g back to sleep. However, the only way I can get it to wake up after it's aleep is go down and press the front pa...
Mar 05, 2013Guru - Experienced User
There are several freeware packages that will send WoL packets to your NAS.
So maybe try googling "wake on lan freeware"
