DiBosco
Mar 05, 2013Aspirant
How do I use wakeup on LAN on Duo v2?
Folks, I have a Duo v2. I have it to be on for one hour a day to back up stuff then g back to sleep. However, the only way I can get it to wake up after it's aleep is go down and press the front pa...
chirpa
Mar 05, 2013Luminary
These are community forums, not Support forums. Community members will help out where they can, but if you need NETGEAR Support, best to contact them directly. http://support.netgear.com/
