DiBosco
Mar 05, 2013Aspirant
How do I use wakeup on LAN on Duo v2?
Folks, I have a Duo v2. I have it to be on for one hour a day to back up stuff then g back to sleep. However, the only way I can get it to wake up after it's aleep is go down and press the front pa...
DiBosco
Mar 07, 2013Aspirant
Thanks for the sarcastic suggestion of Googling wake up on lan utility, but if you don't know it is a generic program that doesn't help. I tried Googling things like "wake on lan readynas" "wake on lan readynas duo" "wake on lan readynas duo v2" etc etc and there were lots of questions about it, does it actually work etc, but nothing saying it's just needs a application that you can run on your OS of choice that sends a magic packet. I thought at first it was a Netgear specific application I couldn't find or that you had to ping it or just try and log on to its inbuilt web page.
I did not just come here without spending time trying to find the answer first. It's one of those classic things where it's such a basic hole in your knowledge, people find it hard to think back to when they'd never come across something new and they just assume the person asking the questions knows that basic premise.
Anyway, thanks for the help, Stephen.
