DiBosco
Mar 05, 2013Aspirant
How do I use wakeup on LAN on Duo v2?
Folks, I have a Duo v2. I have it to be on for one hour a day to back up stuff then g back to sleep. However, the only way I can get it to wake up after it's aleep is go down and press the front pa...
Mar 07, 2013Guru - Experienced User
The depicus package looks reasonable, there are several similar ones. All require knowledge of the NAS mac address (e.g., its ethernet address, not the IP address), and they depend on broadcast packets going through your network. They generally won't work over the open internet.
As far as I know, there are no special requirements to get WoL working with the NAS. Not all ReadyNAS models support WoL, but the ones that do should work with any utility. Though I do this in the other direction - the NAS is on 24/7, and I have a WoL addon which I use to wake up the PCs.
