tjuanma
Jul 06, 2015Guide
How to Access to /etc/ ? RN104 6.2.4
Hi everyone...i'm having serveral problems with my nas to make it work with Transimission. Searching for solving problems i've seen that i can access to /apps/ or /etc/ to check some files but i'm no...
tjuanma
Jul 06, 2015Guide
mdgm wrote: The SSH user is root not admin.
Good! It worked.
However...still having same problem on NAS.....i'm considering the option to do a Factory reset on nas....
I have 3x2TB hard disk on my NAS....if a remove 2 of them and leave 1 (that could be erased without problems)...if I do a factory reset and after that i put again the other 2 disk...the infomation will be ok on that 2 disk?
I don't want to loose all my data.
