tjuanma
Jul 06, 2015Guide
How to Access to /etc/ ? RN104 6.2.4
Hi everyone...i'm having serveral problems with my nas to make it work with Transimission. Searching for solving problems i've seen that i can access to /apps/ or /etc/ to check some files but i'm no...
tjuanma
Jul 06, 2015Guide
Ixa wrote:
tjuanma wrote: I have 3x2TB hard disk on my NAS....if a remove 2 of them and leave 1 (that could be erased without problems)...if I do a factory reset and after that i put again the other 2 disk...the infomation will be ok on that 2 disk?
If you will re-insert the other 2 disks, the data that it contains will be all wiped out because it will undergo a resync process.
Even if i have all my disk without raid?
I've them in JBOD.
