tjuanma
Jul 06, 2015Guide
How to Access to /etc/ ? RN104 6.2.4
Hi everyone...i'm having serveral problems with my nas to make it work with Transimission. Searching for solving problems i've seen that i can access to /apps/ or /etc/ to check some files but i'm no...
RX
Jul 06, 2015Luminary
tjuanma wrote:
Ixa wrote:
tjuanma wrote: I have 3x2TB hard disk on my NAS....if a remove 2 of them and leave 1 (that could be erased without problems)...if I do a factory reset and after that i put again the other 2 disk...the infomation will be ok on that 2 disk?
If you will re-insert the other 2 disks, the data that it contains will be all wiped out because it will undergo a resync process.
Even if i have all my disk without raid?
I've them in JBOD.
For example you have already factory reset your NAS with one disk inside that is already on JBOD and let say XRAID is turned off... the moment you insert the other 2 drives that has data in it one-at-a-time, the NAS will not accept it and you will need to format the other 2 drives. Otherwise, if ever the other 2 drives has no data in it, then you will have the option to add parity.
It would be best to back up of all of your data before anything else. :)
