Mattwood
Sep 30, 2017Aspirant
how to add a used drive from my pc
Hi i have a RN10200 can i put a hdd in a bay from my pc (as i need to rescue files from it) into the ReadyNAS without formatting it? so i can get to my files?
Sandshark
Oct 03, 2017Sensei
No, you cannot read the files on a drive from your PC with the ReadyNAS by mounting it internally. As previously suggested, you will need a USB dock and connect that to another PC or (possibly) the ReadyNAS (depending on format). The NAS strictly uses BTRFS format on the internal drives but can read NTFS via USB. I'm not sure what the NAS will do if there is more than one partition on the drive.
