whitebear_99's avatar
whitebear_99
How to connect transmission NT by commandline
I have installed transmission NT from app.
Then it works ,but I woud like to controle this application by termina;.
I googled around and found I have to use transmission-remote or transmission-cli.
I found there is some files in this directory.
/apps/nastools-transmission/bin
drwxr-xr-x 1 root root    180 Mar  1 11:48 ..
-rwxr-xr-x 1 root root 510608 Apr  9  2016 transmission-cli
-rwxr-xr-x 1 root root 510960 Apr  9  2016 transmission-create
-rwxr-xr-x 1 root root 527056 Apr  9  2016 transmission-daemon
-rwxr-xr-x 1 root root 506800 Apr  9  2016 transmission-edit
-rwxr-xr-x 1 root root 547536 Apr  9  2016 transmission-remote
-rwxr-xr-x 1 root root 510864 Apr  9  2016 transmission-show
However if I do
./transmission-remote --debug -l
posting:
{"arguments":{"fields":["error","errorString","eta","id","isFinished","leftUntilDone","name","peersGettingFromUs","peersSendingToUs","rateDownload","rateUpload","sizeWhenDone","status","uploadRatio"]},"method":"torrent-get","tag":4}
* Couldn't find host localhost in the .netrc file; using defaults
*   Trying ::1...
* TCP_NODELAY set
* connect to ::1 port 9091 failed: Connection refused
*   Trying 127.0.0.1...
* TCP_NODELAY set
* connect to 127.0.0.1 port 9091 failed: Connection refused
* Failed to connect to localhost port 9091: Connection refused
* Closing connection 0
[2017-03-05 04:25:05.678] transmission-remote:  (http://localhost:9091/transmission/rpc/) Couldn't connect to server
I can't connect to the server.
I tries to access (http://localhost:9091/transmission/rpc/) but in vain.
Honestly speaking , I am not sure how to controll transmission.
This quesion might be stupid. I would like to know the first step of connecting transmission by terminal or some script.
ProSupport for Business
