h4te
Oct 26, 2012Aspirant
How to create folder DUOv1 via FTP client
I have a Duo v1, latest firmware 2012. 09. With admin user I cannot create folder via Total Commander. What is the problem? I can ssh with root and I can do anything, but it is a little bit unco...
Oct 26, 2012Guru - Experienced User
Are you accessing shares that were created from FrontView?
-If so, try resetting the owners and permissions via frontview's "advanced options" for the share.
-If not, that is the way you should do it. You shouldn't need ssh access.
