zeke561
Jan 06, 2020Guide
How to modify samba config with raidiator 4.2.31
I have a need, if possible, to enable SMB2 on an ultra 4 plus running raidiator 4.2.31. I have read that it is possible with this version of OS to edit /etc/samba/smb.conf to include specifications ...
Jan 07, 2020Guru - Experienced User
Sandshark wrote:
On an Ultra4, you are much better off upgrading to OS6. Besides getting SMB3, you get a completely up-to-date OS and even the ability to move the drives over to a new NAS if you decide to upgrade or if your Ultra dies.
I agree that is the best approach. You will need to back up all your data, since the conversion process is destructive. Also, you won't be able to use Netgear paid support (since they don't support the conversion).
zeke561
Jan 07, 2020Guide
Yes, thanks for the adivce, I agree that upgrading to OS6 would be the optimal solution. For a few reasons it is not a viable option at this time. Running SMB2 is my desired workaround. I have no particular need for high performance, actually the SMB access is somewhat of a secondary function of this device.
BTW the last time I checked, I could not find the necessary files to upgrade. For example, in
there is reference to the needed files but no links to them unless I'm missing something. Can you point me to those files?
thanks
- StephenBJan 07, 2020Guru - Experienced User
You can find the bios download here: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
You could try this: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Enable-SMB-2-on-ReadyNas-x86-v4-2-31/m-p/1455830#M139865
But I'm not sure if the setting will be sticky or not.
- zeke561Jan 14, 2020Guide
It looks like I missed this reply, so belated thanks. Anyway, the procedure outlined in the link, editing /etc/samba/smb.conf is what I tried and does not work. I would try to edit the one in the default directory (/etc/default/config/etc/samba) but I don't want to cause problems I can't easily solve, since SMB isn't my highest priority for this machine and I can work around it.
- SandsharkJan 15, 2020Sensei
Did you insure it was in the [global} section and re-bbot or restart Apache?
smb.conf may be overwritten. I have found a better place to do such things is /etc/frontview/samba/addons/addons.conf, whihc is included by declaration in smb.conf. That file does not appear to be overwritten by an OS update or re-install. That's a two-edged sword, so make sure you get it right
