xtrips1
Jan 03, 2012Aspirant
Howto mount an external path in Readynas Pro?
Hello, I am a Linux newbie, so please, be gentle! I have an application running on my Readynas Pro (Sabnzbd) that I would like to give write access to a drive on another NAS (Unraid) accessible th...
xtrips1
sphardy wrote: You would have to enable SSH access to your NAS and mount the 2nd device via the commandline - you could then create a script to automate this at boot up
Thanks. Can you help me a bit further?
I have enabled SSH on the Unraid and checked that I can access it using SSH via Putty at port 22.
I can also browse to the right folder in the Unraid which is /mnt/user0/Downloads/complete.
I also have SSH running on the Readynas Pro.
I used mkdir /mnt/UnraidNas on the Readynas
then
mount /Novanas2/mnt/user0/Downloads/complete /mnt/UnraidNas
But it does not work.
Obviously this is not the right command.
Any idea?
Thanks
