Lauri
Oct 26, 2015Aspirant
I can shot down fan on my NAS-102
I have a Netgear NAS, by product model: RN10200, serial No: 3ER . . . 06E, purchased in July 2014. This Netgear NAS controlled by Netgear Ready NAS RAIDar 6.4.0, and the NETGEAR Powerline Utility...
Lauri
Nov 03, 2015Aspirant
The problem with planning of auto-close of NAS-102 have not been solved !
Now i have contact vith swedish "Netgear Support NETGEAR Support Case #25971871"
The issue is not solved yet.
// Lauri
JennC
Nov 03, 2015NETGEAR Employee Retired
Hello Lauri,
I checked your records and you have not registered the SN of the NAS you have. I suggest you ask the support person you have contact with to register it under the case number you have opened so they can escalate the case in case needed.
Please also try setting MTU to 1500 and see if there's any improvement. I also strongly recommend to back up the data.
