chrisyork
Mar 09, 2017Aspirant
I P Conflict
Hi, After a power outage and reboot my duo is sending out 2 MAC address to the router which is causing a conflict. The router is an Asus RT- N56U and I am running the latest version of RAIDar. Any a...
Sandshark
Mar 10, 2017Sensei
Yes, but if your NAS is set to a static IP, then it will ignore the IP address handed out by your router and use what it is set for. That is the likely scenario and why that's not the best way to reserve addresses. The better method is to reserve the address within the router. If you cannot do that, then set the static address to somethng well out of the range likely to be assigned by the router, like xxx-xxx-xxx-200. If you change it, though, remember that anything else you set up that relies on the static address will also need an update.
chrisyork
Mar 11, 2017Aspirant
Hello,
Thanks for the additional information, I have now reserved the IP address within the router for the NAS so hopefully that should be OK
