mpjbay
Dec 31, 2017Aspirant
I shut my NVX down, now it does not boot. HELP!!!
My ReadyNas NVX has worked greeat for years however, I turned it off before I left town. Came back and my NVX does not boot when I push the start button. Nothing happens. Any suggestions? Tha...
Dec 31, 2017Guru - Experienced User
Do you mean that there is no sign of power anywhere (no lights on the front, no leds showing on the NIC(s) in the rear)?
If so, your power supply has likely failed. It is possible to replace it ( Sandshark is a good resource on your options there).
You can also get a new OS-6 x86 NAS (RN300 or better). You can't just migrate the disks to OS6, but you can temporarily mount the NVX data volume so you can back it up. https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
- mpjbayDec 31, 2017Aspirant
Correct no power. I oredered a new PS last night asfter posting this.
- StephenBDec 31, 2017Guru - Experienced User
If you bought a stock supply, you will need to modify the pinout. Here's a thread that might me useful: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/Power-supply-failure-and-replacement-on-NVX/td-p/894812
Thank you :)
