alokeprasad
Nov 30, 2012Mentor
If I replace my 1 TB disks w 2 TB disks, will disks defrag?
I plan to replace the two 1 TB disks in my Duo 1 (X-RAID) with two 2 TB disks. One at a time. Hopefully, all will go well and my data will be preserved. Will this result in the two 2 TB disks gett...
alokeprasad
Nov 30, 2012Mentor
I don't remember doing a factory default ever. That probably happened 4-5 years ago. when I purchased the DuoV1.
Do you suggest going through the disk upgrade process (switching disks), doing a backup, saving configuration, doing a factory default, restoring configuration, restore from backup?
Will saving configuration and restoring it after factory default mess up anything? That will restore my user accounts, volumes on the c drive etc. I'd like to restore configurations, if I could.
