alokeprasad
Nov 30, 2012Mentor
If I replace my 1 TB disks w 2 TB disks, will disks defrag?
I plan to replace the two 1 TB disks in my Duo 1 (X-RAID) with two 2 TB disks. One at a time. Hopefully, all will go well and my data will be preserved. Will this result in the two 2 TB disks gett...
mdgm-ntgr
Nov 30, 2012NETGEAR Employee Retired
There's some advice on my website (rnasguide.com)
One thing to note is that you should re-install any add-ons you had installed before the factory default (if you still wish to use them) before restoring your config
