alokeprasad
Nov 30, 2012Mentor
If I replace my 1 TB disks w 2 TB disks, will disks defrag?
I plan to replace the two 1 TB disks in my Duo 1 (X-RAID) with two 2 TB disks. One at a time. Hopefully, all will go well and my data will be preserved. Will this result in the two 2 TB disks gett...
HERBIEO
Nov 30, 2012Aspirant
alokeprasad wrote: Thank you. I am going through the site .. very helpful.
Quick Q: How do I verify that a Frontview backup to an attached USB drive is good? Is there a "verify after backup" option?
Or do I depend on the logs (which ones)?
If your a windows user you could use this free program to verify your backup i have used this myself and have not found any problems with it > http://www.exactfile.com/
