wazhappenindude
Aug 16, 2015Aspirant
Improve BitTorrent Sync Speed on LAN
Hello, I have a ReadyNAS 102 and installed the BitTorrent Sync app version 2.0.105. I also installed latest BT Sync client on my Windows PC to synchronize/backup files to ReadyNAS. I have eve...
BrianL2
Aug 18, 2015NETGEAR Employee Retired
Hi wazhappenindude,
I haven't tried using BT Sync client, but I would recommend you to create a backup job that copies your PC files (folder or volume) to one of the shares in your ReadyNAS system. I hope you could have a quick try and see if the transfer speed will be much faster than the 5-6mbps speed that you are currently getting from the 3rd party backup software that you're using.
Windows backup - http://kb.netgear.com/app/answers/detail/a_id/24913
Hope this helps!
Kind regards,
BrianL
NETGEAR Community
wazhappenindude
Aug 21, 2015Aspirant
Hello,
When I copy files directly to the ReadyNAS, the transfer speed is between 30-40 MB/s.
Thanks,
Roehl
- StephenBAug 28, 2015Guru - Experienced User
wazhappenindude wrote:
Hello,
Thanks,
Roehl
I've measured about 50 MB/s write speed with NasTester (http://www.808.dk/?code-csharp-nas-performance). The PC performance can play into this, but also RN102 apps. Do you have antivirus turned on?
I haven't played with bt sync, so I have no specific advice there. Other than the obvious - the RN102 is the entry level NAS, and the CPU gets loaded down very quickly.
