wazhappenindude
Aug 16, 2015Aspirant
Improve BitTorrent Sync Speed on LAN
Hello, I have a ReadyNAS 102 and installed the BitTorrent Sync app version 2.0.105. I also installed latest BT Sync client on my Windows PC to synchronize/backup files to ReadyNAS. I have eve...
wazhappenindude
Aug 21, 2015Aspirant
Hello,
When I copy files directly to the ReadyNAS, the transfer speed is between 30-40 MB/s.
Thanks,
Roehl
Aug 28, 2015Guru - Experienced User
wazhappenindude wrote:
Hello,
Thanks,
Roehl
I've measured about 50 MB/s write speed with NasTester (http://www.808.dk/?code-csharp-nas-performance). The PC performance can play into this, but also RN102 apps. Do you have antivirus turned on?
I haven't played with bt sync, so I have no specific advice there. Other than the obvious - the RN102 is the entry level NAS, and the CPU gets loaded down very quickly.
