jonswepiii
Nov 23, 2012Aspirant
incorrect match with Plex
Hi I have Cars (2006) and Maters Tall Tales (2010) on my ReadyNas drive, but PLex sees both of them as Cars (2006). I have changed the metadata manually, and that is ok, but it still show the le...
majello
Nov 26, 2012Aspirant
i would suggest turning offthe plex dnla server. it really isn't ready for primetime. for some samsung tv models prior to 2012 there's a dedicated plex app you can download via smartcenter. and it works way better than anything else. same goes for iOS and androids. as for the ps3, the dnla server included with the readynas works fine, so i go with that.
regarding matching movies, try setting the metadata agent for the secion to freebase, seems to work better than cine21, at least for me. the scanning does take ages, that's mostly plex talking to all sorts of internet services, not the nas.
and in the most recent version of the web manager there's a nice button that lets you fix the matching result, you can even perform manuals searches there. very handy.
cheers
s.
cheers
s.
