jonswepiii
Nov 23, 2012Aspirant
incorrect match with Plex
Hi I have Cars (2006) and Maters Tall Tales (2010) on my ReadyNas drive, but PLex sees both of them as Cars (2006). I have changed the metadata manually, and that is ok, but it still show the le...
jonswepiii
Nov 26, 2012Aspirant
I can will try unchecking cine21 for future matches, but currently the cars / maters tall tales was the only problem one...it was in the end the custom search that eventually had luck with, thanks.
with regards to the plex Server, I found this the nicest one as all my clients, inc the 3rd party ones, see its thumbnails very well (although allshare does skew them to a diff ratio) and most of the imte I dont have to add them manually either.
However, if I do want to "turn off the PLex DLNA" how would I do this? and wouldnt that just make having it pointless??
And while Im asking "how to..." questions, if there is a need to update PMS, how would I do this as mine installed on the ReadyNAS, is it as simple as putting the new .bin file on as I do to first install it?
Thanks again for advice
PS StephenB my files are predominantly .mp4s with a few .m4as thrown in! Keeping the ISO files separate until I have devices that can play them!!!
