bryanz
Jan 23, 2011Aspirant
Incremental backups from snapshot to USB drive not working
Hi, I have a backup job on my 4.2.15 NVX that runs manually (no schedule) that copies from a snapshot of the C volume to an external USB drive on the front USB port. The backup runs fine, but the incr...
bryanz
Jan 28, 2011Aspirant
I've been able to replicate this on two different NVXs, both with and without snapshots.
I did some digging under the hood and found that local backups are run using the following:
cp -vua '.' $'/my_usb_drive/' &> ${TEMP_COPYLOG}
cp does not copy incrementally, it only copies all files. So maybe it's not possible to do incremental backups to a local USB drive, even though the web interface makes it look like you can?
