JMcIntosh
May 25, 2015Aspirant
Incremental Backups not working with SMB Shares
Hi, Environment: ReadyNAS 3130 8TB 4 drives OS v6.2.4 Single Volume, Raid 5, X-Raid formatted 8 Shares defined with SMB Protocol enabled 1.3TB of data, 4.14TB free space. Everything in the gr...
May 27, 2015Guru - Experienced User
You can also use 127.0.0.1 for the IP address - by convention this is localhost on computer systems, so it avoids the need for a static IP address.
Though reserving an IP address for the NAS in your router is a good practice (and more robust/managable than using static addresses)
