imzeek2u1
Nov 18, 2011Aspirant
Infrant X6 bootloader failure
Hello. I have an original Infrant X6 (purchased from Infrant) that was running 4.1.8 just fine. I replaced it with an NV+ and attempted to reset the old X6 back to factory defaults through the web GUI...
chirpa
Nov 18, 2011Luminary
Sounds like it was an OEM, USModular/Momitsu/Snazio/etc.
Steps to get around that is to put older 2.x firmware on it, install Fix Vendor ID add-on, reboot twice, re-upgrade to 4.x.
Previous threads on the issue: viewtopic.php?f=20&t=25855 viewtopic.php?p=223119#p223119
Add-on: http://www.readynas.com/download/addons ... ID_0.1.bin
