imzeek2u1
Nov 18, 2011Aspirant
Infrant X6 bootloader failure
Hello. I have an original Infrant X6 (purchased from Infrant) that was running 4.1.8 just fine. I replaced it with an NV+ and attempted to reset the old X6 back to factory defaults through the web GUI...
imzeek2u1
Nov 19, 2011Aspirant
Yes, but I also had to do a factory defaults reset through the GUI because the media and backup volumes were missing after the initial install. Does this remove the add-on or should it have still been applied? I assume the fix was OK because 4.1.8 was able to be installed, right?
