imzeek2u1
Nov 18, 2011Aspirant
Infrant X6 bootloader failure
Hello. I have an original Infrant X6 (purchased from Infrant) that was running 4.1.8 just fine. I replaced it with an NV+ and attempted to reset the old X6 back to factory defaults through the web GUI...
imzeek2u1
Nov 19, 2011Aspirant
No, unfortunately the factory reset didn't solve the issue with no access to the web admin in 4.1.8. The X6 has 256MBs of RAM. I ended up stepping back down to RAIDiator-2.00c1-p5 which at least gave me back access to the web admin. I suspect that the error I'm getting about my system not supporting the Vendor ID patch might be related to what's causing 4.1.8 to install but not be accessible via the web admin. Is there more than 1 version of the Vendor ID patch? (ie. one specifically for older 2.x firmware). This is all very odd, because I was running 4.1.8 before on the X6 and only got into this dilemma when I tried to perform a factory reset which failed. I'm simply looking to prepare the X6 for resale on eBay.
