NickHark1
Nov 15, 2011Aspirant
Is iSCSI what I should use for my large audio library?
I have a large audio library and I use, unfortunately, outdated media players, (Netgear MP101) to stream my music. I outlined my headaches in this post: viewtopic.php?f=22&t=58813 and I was advised...
TeknoJnky
Nov 15, 2011Hero
NickHark wrote: The server software that came with the MP101 will only properly function if the media files
are on a local PC. A mapped drive does not work.
this would be one of the only reasons to do so
So, I could run the media software on an XP machine and it would access the target drive on the ReadyNAS and the PC would stream the media files.
yes, iscsi appears as a direct attache drive (ie like an internal or usb/firewire drive).
Does iSCSI seem like it will work for me?
should
Do I have to change the formatting of the target for any reason?
not sure what you mean here.
Can I just make the target an already created folder in my media share, eg. "ReadyNAS3/media/music"?
no, as mentioned above, the iscsi drive appears as a local/attached drive to your PC and all the applications on it. It has to be formatted for use just like a normal hard drive, its like a virtual drive or virtual cdrom but stored on the network.
the data in your media share and iscsi drive are totally separate, the only thing you can do is make a duplicate copy of one to the other (like with robo copy or something), however there is no 'two way sync' between them.
