gopterman
May 08, 2013Aspirant
Is my Duo v1 dead?
I have a ReadyNAS Duo v1 with twin 1TB drives that has served me well until recently. After a number of power cuts that affected the area where I live, I now have a NAS that won't boot properly. ...
May 08, 2013Guru - Experienced User
If you still see the files, then you are correct - the factory default didn't work.
If you have all the files backed up, try deleting the partitions on drive 1 on a Windows PC, and power up the NAS with only [blank] drive 1 installed.
