digitaldentistr's avatar
Nov 05, 2015
Is RAID 5 hot swap as is RAID 1?
On ReadyNAS Pro2 products with 2 drives, you could just wap the drives from one unit to another (putting in same exact location) and it didn't require any configuration or setup.  Is this possible fo...
  • StephenB's avatar
    Nov 05, 2015
    You can migrate disks to a compatible unit (just like the ultra/pro 4.2.x systems).  That is, you could migrate from an RN300 NAS to an RN300/RN500/RN700 system, as long as it has enough drive bays.
    This isn't "hot swap" since the systems are powered down when you migrate the drives.  Your use of "hot swap" in the title is perhaps complicating the replies.
ProSupport for Business
