delange
Oct 09, 2021Tutor
Is ReadyNAS leaving the small business market?
Hello, I was in the market for a new 4 bay NAS to replace my ReadyNAS NVX. This NAS has served me well and if it wouldn't for the lack of software upgrades I would still use. It is very well made...
Oct 10, 2021Guru - Experienced User
delange wrote:
is ReadyNAS leaving the small business market space?
Netgear hasn't said, but there is some evidence that might be the case.
Certainly you should be looking at all your options (including other vendors). Whether they are exiting the business or not, inventory is scarce and often overpriced.
- delangeOct 10, 2021Tutor
I bought a QNAP TS-453 NAS this weekend. The QNAP is definatly a lot faster but that is too expected from a product that is 10 years younger. Build quality wize, the ReadyNAS is in a different leaugue. That is one of the reasons why ReadyNAS was my first choise.
But anyway, can't look back now. The QNAP does do everything I need it to do.
My NVX is now entering a new phase in its life: it is my new backup device. Every night it will boot up and the QNAP will then dump its backup onto the ReadyNAS.
- StephenBOct 11, 2021Guru - Experienced User
I use my older NAS similarly. You might want to run the backup on the NVX - that avoids any glitches if the ReadyNAS takes longer to boot than expected. Also the NVX will postpone its shutdown if a backup job is running on it. Of course it can't do that if the QNAP is running the backup script.
FWIW, some legacy ReadyNAS can be converted to run OS-6 firmware. But the NVX isn't one if those.
- delangeOct 11, 2021Tutor
Thank you for the tips Stephen. I have a time windows of 10 minutes for the NVX to boot up before the QNAP's schedule kicks in. But I'll look into your suggestions.
Yeah, I have looked at upgrading my NVX to OS6 but indeed that isn't supported.
- Retired_MemberOct 15, 2021
That because netgear failed that market. I made a lot of bad decisions in my life but getting the readynas was the worse. Literally the worse mistake for any IT guy
- delangeOct 15, 2021Tutor
Well, as they say, the grass is always greener on the other side... I now have a QNAP TS-453 as my main NAS. It isn't without its problems either. And thrying to contact support is not straight forward either.
I would have bought a ReadyNAS again if they had a model that would fit me.
Anyway lkxfhmliucdjhlg why do you say that getting a ReadyNAS is one of your worst decisions? Why trouble do you have with it?
- NAS2304isbadOct 16, 2021Aspirant
Becasue it is terriible, does not work, has an extreme access and permissions issue, and has zero features.
