delange
Oct 09, 2021Tutor
Is ReadyNAS leaving the small business market?
Hello, I was in the market for a new 4 bay NAS to replace my ReadyNAS NVX. This NAS has served me well and if it wouldn't for the lack of software upgrades I would still use. It is very well made...
Oct 10, 2021Guru - Experienced User
delange wrote:
is ReadyNAS leaving the small business market space?
Netgear hasn't said, but there is some evidence that might be the case.
Certainly you should be looking at all your options (including other vendors). Whether they are exiting the business or not, inventory is scarce and often overpriced.
Retired_Member
Oct 15, 2021That because netgear failed that market. I made a lot of bad decisions in my life but getting the readynas was the worse. Literally the worse mistake for any IT guy
- delangeOct 15, 2021Tutor
Well, as they say, the grass is always greener on the other side... I now have a QNAP TS-453 as my main NAS. It isn't without its problems either. And thrying to contact support is not straight forward either.
I would have bought a ReadyNAS again if they had a model that would fit me.
Anyway lkxfhmliucdjhlg why do you say that getting a ReadyNAS is one of your worst decisions? Why trouble do you have with it?
- NAS2304isbadOct 16, 2021Aspirant
Becasue it is terriible, does not work, has an extreme access and permissions issue, and has zero features.
- SandsharkOct 17, 2021Sensei
It works just fine if you do things correctly. You've been offered help if you provide details of your issue(s), but clearly don't really want it; you just came here to grouse.
