delange
Oct 09, 2021Tutor
Is ReadyNAS leaving the small business market?
Hello, I was in the market for a new 4 bay NAS to replace my ReadyNAS NVX. This NAS has served me well and if it wouldn't for the lack of software upgrades I would still use. It is very well made...
Retired_Member
Oct 15, 2021That because netgear failed that market. I made a lot of bad decisions in my life but getting the readynas was the worse. Literally the worse mistake for any IT guy
delange
Oct 15, 2021Tutor
Well, as they say, the grass is always greener on the other side... I now have a QNAP TS-453 as my main NAS. It isn't without its problems either. And thrying to contact support is not straight forward either.
I would have bought a ReadyNAS again if they had a model that would fit me.
Anyway lkxfhmliucdjhlg why do you say that getting a ReadyNAS is one of your worst decisions? Why trouble do you have with it?
- NAS2304isbadOct 16, 2021Aspirant
Becasue it is terriible, does not work, has an extreme access and permissions issue, and has zero features.
- SandsharkOct 17, 2021Sensei
It works just fine if you do things correctly. You've been offered help if you provide details of your issue(s), but clearly don't really want it; you just came here to grouse.
- schumakuOct 17, 2021Guru - Experienced User
And you think that a much more complex NAS does magically solve all your issues? Appears your only answer is to create a new rant account instead of following the most simple troubleshoot information offered, provide information of your RN2304 current status, what you have configured, what you intended to achieve, ...
And yes: I would put up the very similar answer on another NAS vendor community, too.
- NAS2304isbadOct 17, 2021Aspirant
I don't no what to tell you. I make a account. I make a share. I give eprmission and access to that newly created user. I go to a computer. I open network. I click on the NAS. It asks for name and password. What I made does not work, never has work and nothing will make it work since I opened it's box and was baffleded that there was no way to secure the drives to the drive caddy and I came on here was told there should have been screws in the box months and motnhs ago. The only account that works is my netgear account. Every and any other account made will not work at all. A working single account NAS for a office? Ha
