Retired_Member
Jun 17, 2012iSCSI and OS X, for Spotlight
My NAS is close to running low on space, and the problem I'm running into is that it's just painful to sort through the years worth of data I've stored on there. I've been lazy at times, and just kep...
mdgm-ntgr
Jun 18, 2012NETGEAR Employee Retired
The iSCSI target would be a file on the NAS. Expansion would still work as normal. After expanding the volume you could then looking into adding more space on the iSCSI side.
GlobalSAN is no longer free. ATTO is regarded as the best initiator for Mac, I think.
Currently I don't use iSCSI, so don't have much more to say on that.
I believe that there's a setting for Netatalk that can be changed to enable fast indexing for the share. Are you only accessing the NAS over AFP?
