WingDog
Jul 23, 2015Guide
iSCSI strange behavior with random write (utorrent)
Hello, I'm using RND6 Pro with E7300/4Gb/6*2Tb WD Black (x-raid/raid5 mode) and windows 8.1 x64 as client. all NICs are Gigabit. One NIC at client and one NIC at RND. Later I had FW 4.2.27 and one...
WingDog
Jul 23, 2015Guide
Hello, mdgm.
LUN is Thick.
no, bit-rot protection is off (default setting)
no snapshot (disabled)
sync write is allowed (default setting)
mdgm-ntgr
Jul 23, 2015NETGEAR Employee Retired
Can you disable sync writes and see what difference this makes?
Do you recall which firmware you were running when you created the LUN?
- WingDogJul 23, 2015Guide
mdgm
I think this is one cause
with Disabled sync writes it's a very-very little faster.
FW R4toR6_latest-beta.bin from your post at previous forum.
